I continue to find that I really miss an app-wide (or should I say “Doc-Wide” here in Coda…) Activity Stream. At times I inadvertently will click on a key combo when something is highlighted and delete by mistake. In these situations, and others, I find myself longing to navigate to the entire “Activity Stream,” but for now it’s not there!
This is a basic feature that I hope you guys can make happen for the entirety of a doc in one view. I also think the Activity Stream currently for rows, incorporated into Comments, could use a bit more detail, for example:
- when relations are added
- when any change is in a column. I seem to be able to make some changes at times that don’t register in the row’s Stream, but I’m not sure what does, and what doesn’t.
Thanks guys!
