Wondering if it would be possible to override a table’s defined display column within subsequent views?
Two simple usecases/examples:
lookup columns
Say you have a people table which contains a person’s full name and a person’s initials (among other details). You have a doc with many other tables/views which frequently lookup people. 95% of the time, it makes sense for the display column to be the person’s full name, but sometimes it would be nice to display their initials in a lookup column instead of their full name. Especially when you’re trying to squeeze as many columns as possible into a crowded table!
gantt charts
Currently the display column shows up as the block title in the gantt chart. Again, it would be great if you could specify a different column to display instead of the display column within the individual chart settings.
I can prepare an example doc if that makes things easier to understand. Also, maybe I’m missing something so suggestions are welcome!
i.e I still want the ability to change the assigned customer in the Service Request table, but to only have their initials show up. Does that make sense?
Awesome! but then it is not possible for me to change the “Person” assigned to that “Service Request” from that table, which is my desired functionality
No worries, we could add a button to open the row to be able to update.
I will not be able to work on that immediately, but tomorrow around this time it could be fixed.
Hi @Jean_Pierre_Traets thank you! No worries at all, thank you for helping me out. There is no rush.
I’ve implemented what I think you mean. To do this, I replaced the initials column with a button column, which then opens the Person detail form to update the person. This works ok, but would ideally be able to update the person assigned in-line in the table view. Do you know if this is possible?
Also, I forgot to mention that multiple people could be assigned to one Service Request. You’ll see what I mean in the doc.
Unfortunately it’s not possible to have different Display Columns for different uses.
If you totally wish to have this UX where the persons selects initials and not a full name in a dropdown, the way to work around this would be to introduce a Select column that’d be populated with initials, then look up a corresponding person row that matches those initials. With Gantt charts, you’d have to make a separate table that you’ll base your chart on. Basically you can always introduce a separate table, but that could be a hassle to keep the list of rows there in sync with the list of rows in your actual source-of-truth table.
It will not be possible to update without expanding this row.
I added a button to expand, in case you work on mobile, it should make it more user friendly, but not necessary. More a personal choice!
I saw that you have the multiple person selection working
