In the text canvas I can put a formular anywhere using command “=” . Onnce calculated the formular can be named and I can place its value anywhere on the text canvas using command =.
However inside a text cell (of a text column in table), the = command won’t work. I think it’s related to the text data type in Coda can not hold the numeric value so it won’t allow using formular.
Anybody know how a work around this issue? I’m quite sure that many people who use table for weekly planning will be happy to reference some mettrict to the weekly planning text.
Don’t forget that you can put individual formulas in Canvas column cells. You have to name each one to reference them outside of the cell, but it might give you the flexibility you need.
