Possible to change text color?
New to Coda here and creating my first todo list. BUT, I can’t find a way to select a few words and change their color. Seems not possible. Could someone confirm this for me?
You should be able to change text color in table cells and in the canvas. Here’s a GIF of how it works.
If your setup is different, or you’re not seeing the same options, post a little more info and we’ll check it out.
CloudApp
