Hi Coda team,
Upon using the new right-view modal, I noticed that if I change focus to the page, the ESC keyboard shortcut doesn’t close the modal anymore.
One use case in which that happened was when I pressed a row button to open a modal. Because now the page is exposed, I was able to access the table behind the modal while it was opened. Instinctively, to close the modal, I presses the button again, as a toggle. This changed the focus to the page and, of course, didn’t close the modal. Then the second thing I tried was to press ESC, but the focus was on the page by then, so nothing happened.
The right-view feature is actually REALLY helpful for my implementation. But the lack of a toggle quality created this new problem. I was trying to fix that with OpenWindow() approaches, but couldn’t make it work because the button is pressed throught a view, not the original table in another page.
So I’m here to talk about this “bug” (more of a UX problem) and to ask for help on how to make a toggle open/close button without changing context (just closing the modal).
thanks
