Print from a Coda doc to a Dymo Labelwriter using URL parameters
A Coda user asked about being able to print to a Dymo Labelwriter from a Coda doc. After seeing a GitHub repo with an address field to print from a webpage, I thought it might be cool if column values could be sent over as URL parameters and used for the Print dialog.
This is a quickly hacked together solution that seems to work alright, but improvements are definitely welcome if anyone is interested.
The GitHub repo with the webpage code is here:
The Coda doc template with a sample table setup is here:
I don’t have this up as a sample site, but you can test locally or upload the repo to your own hosting.
Dear @BenLee ,
Thanks for posting this onto the forum.
How exactly would I get this to work locally? Do I have to download the repository or something? Sorry I am a low code developer (at present) so this GitHub business flies over my head…
Regards,
Shaheed
