Think about how you can insert the same Table into multiple documents using reference.
Wouldn’t it be useful to do that with Paragraphs?
You could create summary documents that pulled in sections from multiple documents.
You could create new documents that summarised and ordered the information in different ways.
For example you could create a document on the french revolution and view the information chronologically or by person/group, all using the same text.
Vote up, if you would find this useful.
