@Krunal_Sheth do you have any solution for hiding sections? The solution you described above works well for hiding lower level data but looking for a temp solution for section permissions until an official update for this.
Any update on this one?
2021 here and we still have no proper per-section permissions
This feature will move Team Plan to another level.
This doesn’t work for the ever-present search bar, which gives access to everything in the document to all editors.
