I have table A with a button that adds rows to table B.
Table B has modified on and created on columns.
Rows being added to B from A using the button are not showing in the two columns above
Hi @Paul_Kazuwa
Would you mind adding a bit more context ? ![]()
I think sharing a sample doc reproducing the issue you’re encountering would be helpful here ![]()
