Slack reminder from coda's slack bot
Hi Community,
Is there any way to create an automation to notify any overdue task directly to slack by using automation bot?
Thank in advance!!!
Hello, yes there is a way by using the Slack Pack in your Coda doc. Here are some example use-cases of Coda and Slack integrations: Slack + Coda
@Simone_Smerilli Thanks for your help!!
