Hello everyone,
First of all, thank you for reading this question and spending time thinking about it.
I don’t know if what I want to do is even possible. I’ll try to summarise. I have three tables:
Month
with a single column named Month with a row per each month:
- 2019-01-01
- 2019-02-01
- 2019-03-01
And so on…
Monthly money
This table is the invoices table with the following columns:
- Month (Lookup from Month table)
- Client
- Project
- Estimate
- Invoice
Please note: There can be multiple rows with the same “Month” and I use the Row grouping to see the total money incoming each month.
Costs
This table is a list of the costs per month but I would like to have a column with the reference of the incoming money. The columns I have are:
- Cost 01 name
- Cost 01 amount
- Cost 02 name
- Cost 02 amount
- Cost 03 name
- Cost 03 amount
- Total (Sum row with the sum of the previous amounts)
- Total income (Formula. See below)
Please note: This table has one row per month, that’s why I want to have a column with the total of the income.
Total income formula
As I want to display a graph with two lines, one for the costs and one for the income, I wanted to include the “total income” here.
I’ve tried the following formulas and neither of them work:
01
[Monthly money].Invoice.Filter([Monthly money].Month.Contains(thisRow.Month)).Sum()
The problem of this formula is that the result is the total of the whole column Invoice, so it doesn’t Filter.
02
[Monthly money].Invoice.Filter([Monthly money].Month.Contains(Costs.Month)).Sum()
Same result as the previous formula.
03
[Monthly money].Invoice.Filter([Monthly money].Month=thisRow.Month)
In this case, there’s no result, only empty brackets [ ]
Any help will be extremely appreciated.
Thanks for reading.
EDIT: Solved thanks to @Daniel_Stieber formula:
[Monthly money].Filter(Month = thisRow.Month).Invoice.sum()
Have a look at the templates that you can easily add in your doc, from how others have solved certain challenges, you will be able to gain fast access to the know how.
