Some advice on structure for handling project and personal todos
Hi,
Trying to get my head around Coda and move away from Trello/OneNote/Bear.
I am trying to create a structure for my work projects like so;
Dashboard (where I would like open tasks shown)
  • Customer 1
– Notes (multiple pages)
– Todo’s
  • Customer 2
– Todo’s
etc etc
I would like to have an overview at the Dashboard document level that shows all the ToDo/In Progress tasks from each of the customers below it (i.e. from customer 1 AND customer 2).
Is there a way to do this? Do I need to change the structure or use different functionality? How does Coda know it is a Todo to filter etc?
Apologies if this is basic stuff etc
Hey @Phil_White1 welcome! I think you might have some success in the template gallery to find some templates that work and then pick them apart and put them back together.
The way I would approach your concept is to create a database table called ‘_tasks’ that holds all of the tasks, and it might have columns [task], [due date], and [customer].
Then in each customer page, create a view of _tasks filtered to show [customer]=customername. Its best practice to have one master table with all your data and then serve it up in your doc with views.
Hope this makes sense. The videos @maria makes also goes through the schema basiscs very comprehensively. If you want more help here, I would recommend creating a doc and then posting an embed so the community can see where you are stuck.
