Some columns hidden in card view
In a table with 3 checkbox columns, a name and date property in Card view the first column’s title is hidden.
If I reorder the columns the column on the first position is always hidden. If I just show 1 column the name is also hidden:
Also if I set “column labels” to be visible the first column’s label is still hidden:
How can I force the card view to show all columns?
Hi @Zsolt_Marcsev
this happens, because it takes the first column as the “title” of the card. a trick to get around it would be to have a text column thats blank as first column.
I have recreated your doc in the link below for your reference.
Missing 1st Column Name in Card View
Hope this helps! :blush:
Cheers!
Mel
Thank you! This worked perfectly.
