Anyone have any solutions (aside from Zapier) of how to sync Coda data outside of Coda?
For example, we are using our Coda doc as a source of truth around project data. My program managers would like to utilize this as a “data feed” into their BI tools (or maybe more simply something like Tableau).
Would love to hear folks’ experiences. What apps did you export Coda data into? Did you have to custom configure/write something to get it to work? What are the pros and cons?
@Camille_Nussbaum
Hello,
Exports are quite vast but if it’s a table, exporting to Airtable is quite easy to set up with the Airtable Lite plugin for example.
Could you be more precise about the export of your data?
What do you want to send them to, is there an API for example to communicate with your data recovery service?
