Hi All,
I’ve run into a strange problem. I have a field that concatenates a form URL and adds in a hidden field. This URL is sent as part of an email message using the Gmail pack:
https://coda.io/form/Untitled-Form_dfWrQXd7rYU?Email=bradley@myurl.com
However, when the URL is clicked in the email, the email address portion of the string is stripped away and I can’t figure out why?
What would cause this?
Hello @Bradley_Skaggs
Try to encode the email to URL first and check if it works
Something like this:
Concatenate(
“https://coda.io/form/Untitled-Form_dfWrQXd7rYU ”,
“?Email=”, EncodeForUrl(“bradley@myurl.com ”)
Best regards
Arnhold
Thanks. It’s definitely an encoding issue. I decided to change the variable to the row number and it worked. Thanks for taking the time to reply!
system
Closed
February 3, 2025, 6:30pm
4
