So we are actually making some researches on Artistic Direction for our next game, and we are copying/pasting images on a canvas.
The problem is that we can’t add more than one image on the width of the canvas:
I just tested this and I’m able to add multiple images next to each other as long as they don’t exceed the width of the canvas for text, which is 800px on the narrow layout and 1,000px on the wide layout. I’ve tried both uploading images and the Image("url") formula and they both work.
Add a space or two, then backspace, and try resizing. It should jump up next to the other one.
Thanks @BenLee
The problem is that on Chrome, embedded videos are hard to resize.
And it was more of a feature request to be able to decide the width of the page, like a free form. I could also be an argument for other features request like Mind Map
We are looking at some work on the Canvas. This is likely a larger layouts item though. I’ll pass this along to the team and make sure they see this post.
Hey have you tried to have a table of images and then use a concat() or formulamap() to display them on the canvas? This will allow you to have them next to each other, I think in the way you are wanting @tomavatars.
Hi @Johg_Ananda and thank you for the suggestion, but I think it’s a bad idea. It works of course but it is a workaround and UX wise, it’s terrible.
Because I just want to quickly add images on the canvas, and not have too much operations to do in between.
