I have a table view that has 1 row.
I would like to use a column from that row as a filter on another table.
I have tried things like this in the table filter but with no luck. Is this possible?
fieldname = First.([other table name].[field name])
From an initial glance, it seems like that should work?
Can you share a dummy doc?
I’ve had a lot of luck with the .ToText() function in this type of issues.
So in your case:
fieldname.ToText() = First.([other table name].[field name].ToText())
That was it! I had tried using .ToText() on the other table but not the table being filtered.
Thank you!
Before it’s too late and this becomes the bad habit of you both, I should intervene and say that you should never ever use ToText() to fix things unless you actually understand what you’re doing and have a good reason to use it.
Please share your sample doc and I’ll explain you why.
