I am trying to create the behavior that if I select an item using my selector, it both shows the corresponding table value inline, AND highlights the row in the table.
Here is an example.
When exploring the conditional formatting option, I see an option to create an interactive filter, which works great. But the I cannot use that control to pull up the inline value.
That’s weird … But I had the same trouble with your doc though …
Well, for the conditional formatting, it’s the same thing as you’ve probably already done in your sample.
Here, I create the interactive filter when I create the conditional formatting .
Hmm … would you mind sharing a screenshot of your actual formula @Robin_Bigio ?
It might just have something to do with how you formatted your actual table (at least those 2 fields) …
The brackets indicates there’s a list somewhere (if I’m not mistaken) … So, this might be easy to correct .
