Hi Troy,
Thank you very much for the tip, indeed very useful and handy tool.
Unfortunately it doesnt look like it could help in my case.
What I try to achieve is :
I have a page APage
On APage there is a view View of TheTable
One column of TheTable is a button with some action formula.
If the button is triggerd from View of TheTable on APage, I want it to return something like : “hey, I am triggerd from APage, via View of TheTable, and from this returnvalue you can access other stuff lying on APage, like an on canvas control value, or another view on the same page…” .
Now I got more familiar with the formulas library, and nosed deeper in Pack’s SDK and APIv01 docs, I am pretty sure this cannot be achived.
For now, I use other workaround to reach my goal : a kind of shopping cart.
Project is :
Left side of page would be an Inventory view. Right side a Cart view
On the page, a formula defines a filter for the cart view, proper to the page’s name, or a select dropdown, so the cart view shows only the items that are picked from this page. The Inventory has a button column “add item to cart”. When triggerd, the button should be able to retrieve the filtering parameter from the page, and add that value to the column of the shopping cart.
My workaround : left side inventory is a copy of origninal inventory (not a view), and richt side is a canvas formula such as :
ForEach(
filter(
inventoryTABLE,
CurrentValue.CartPage_01_refefrence.ToText() =
[OnCanvasSelect_filterCriteria_PageContext]
hyperlink(
concatenate(totext(ObjectLink(CurrentValue)), "&view=modal"),
concatenate(
[quantity],
Character(9),
Character(9),
totext([item]),
Character(9),
Character(9),
[details]
.BulletedList()
That formula builds a BulletedList where each row is a Hyperlink opening in modal the cart item, so user can edit initial choices.
Initial choices are made on the Inventory table copy : user inputs the quantity and/or some details for the chosen item. That makes the “add to cart” button available. Clic on the button adds ThisRow’s values to the cart, plus reference to the table context, so the cart selection remains specific to that page. Once the first action is complete, a second action clears the quantity and/or details previously inputted on the inventory table.
The workaround is also necessary because I dont whant to oblige users (many and often changing) to be obliged to singUp in CODA (becaus I know many people ar tired to have to signUp for everything).
I know my project should be built on some SQL or NoSQL web framework, but it is beyond my availability and financial resources…but - last but not least - I am totally amazed by the modularity and the smartness of CODA ! A few more features and tunings would bring CODA to be a dangerous competitor to solutions like FileMaker, GSheets and other RAD platforms, not mentionning I feel like CODA is allready far beyond all these Monday, AirTable, Notion, SmartSheet ant similar stuff I tried many times and enventually stopped by disapointment when discovering the limits of theyre features and modularity…
Sorry, lot’s of blabla, spreading out of the context…
Regards
Angelo
