Hey, can you help me find the order by which the emoji are sorted ? I use the “
” emojis as a category and I usually use “
” as a lower category but when I sort it by Ascending I get “
” which is not what I want.
Can you help me identify the order with which the emojis are sorted ?
Dear @Lois_Boutrash welcome in the community.
A good question, I suggest it should be based on the name of the emoji and to be honest I have so far been using the following method.
Column 1 / Column 2
1 /
2 /
3 /
Performing my sorting on [column 1], to be independent on the content of [Column 2]
Edit: Would you mind to share a dummy of your sample, as in my sample it works well:
