Hi!
I’m new here and still figuring out some things…
I’m trying to implement a new feature to a project management doc we use in our office.
Im trying to determine the work load of each user, in hours, each day, excluding weekends.
For example if a task is allocated 10 hours, the hours / day should be 8 hours in the first day and 2 hours in the second day.
I hope that the embedded doc illustrates better what I want to achive.
Hi @Andrei_Stefanescu1
and welcome to Coda community!
Your formula was indeed correct.
However, you set the column data type as lookup for workload table rather than WBS table.
You could have even set a simple Text data type and let the parser inference the correct type.
Let me know if this helps.
Cheers.
Hi,
Thank you for taking the time to help me.
However, what you just said seems more advanced than my knowledge.
Could you elaborate please? I don’t understand what I have to do.
Sure @Andrei_Stefanescu1 !
I actually already changed the column type of task list in your doc and - as you can see - the test column formula now works.
So, if I correctly understood, you don’t have to do anything else: unless you need other calculations.
test formula wasn’t working because you set the task list lookup column as workload.
Meaning that every entry in that column was considered as a row of the workload table: this is why you could have no access to properties (columns) of WBS table
I simply changed it to WBS lookup and that fixed the inconsistency.
Lookup columns basically say: “We are row(s) of what table?”.
Let me know if you still need do something else.
Thank you,
I now understand why it wasn’t working.
Now what I have to do is find a way to somehow get to “what I want”, that is to divide the allocated hours of each task to the number of days each task takes and add them up in each day.
