@Brendan_Woithe yeah I get it, its kind of abstract so an example should help:
Hopefully this really inspires you! Let me know if you have any ideas on how to improve it.
Hey this trick from @Paul_Danyliuk might provide some relief to your problem:
Fun fact: was looking into Coda’s calendar view for the first time today… aaaand it sucks
Very limited indeed; you really want to use something else @Brendan_Woithe
Yeah its tricky.
I’ve ended up creating a bunch of coloured emoji to help communicate whats going on for a booking!
Unfortunately, working with gcal is not seamless enough for us at the moment. So we’re stuck with the cal view that coda provides.
You can also have conditional formatting to control calendar bubble background FYI. Just need to select “all columns” to apply formatting to.
What is the calendar bubble background? Not sure what you mean.
I’ve got our bookings showing up as three different colours depending on which studio is booked (light blue, grey and light purple… we’re really just trying everything out on one studio, which is why they’re mostly all blue right now!)
I’m secretly hoping you mean something else…it would be useful to have more colours come up.
No, not something else I’m afraid. Event color was what I meant.
Hi All
Just wondering if anyone has found a solution to getting more information into the calendar view? That single line simply doesn’t work…especially if you are trying to print a copy…
Anyone else had any new ideas on this? I would highly value being able to include more info in the calendar view!
