Asking for filter view
I would like to ask how to create a filter bar or a dynamic filter in a Coda dashboard. My data source is located in another table within the same Coda document. I want to build a metrics dashboard with a filter that, when applied, dynamically updates the dashboard. How can I achieve this?
hi @Farah_Bannour , did you consider using controllers and the view of the related tables in your dashboard ,maybe together wit the various columns you can set on your page?
many other makers are far better with look & feel than I am, an certainly happy to help you when you present more details, cheers, christiaan
I would like to make a filter in the dahsbaord
i have this example dahbaord summarize i would like as soon as I choose a filter i find the change in summarize
@Christiaan_Huizer
