I’ve created various tables for our team that we’d like them to use in other documents. e.g. one using cross doc that looks up basic order information, and one for adding tasks linked via Zapier to Asana.
I’d like to able users to be able to easily add these tables to documents whenever they’re needed (e.g. adding a meeting minutes tables when tasks are required), much like the Coda templates can be. With a / command would be ideal. It doesn’t look like this is possible though?
At the moment, users have to go and find the document containing the table I’ve set up, and then manually select and copy paste this into the document, and also click to duplicate data (not a view). Which is a bit of a faff.
Is there a more straightforward way for them to add a copy of a table I’ve made? Does anyone know if there’s a saved user template feature in the works?
