I can’t create a Jira issue of type “Epic”. I get an error each time. Changing the issue type to Task or Story works fine. Any ideas?
I’d like to create Epics from Coda, too
Still generates an error…
Dear @Gannon_Hall1,
Better now then never, this might be what you have been looking for:
This might be an issue with Jira’s different types of projects. I’m not sure if our pack can use epics if it’s a “Classic” project. I think the “Next-gen” projects should work for an epic.
I’ll try to test this out and see if this is the issue.
I checked with engineering and it’s a known issue and currently we don’t have a solution. It’s in our notes and we’ll check it out and see if we can get it up and running.
Same thing. This would be great!
Any news on this bug? I’m doing a manual workaround still. Solid support for the Jira object model t (Epics, etc,) would be awesome.
FYI that the workaround for this is to use Zapier as it supports the creation of Epics for “classic” projects in Jira.
