Hiya Codans,
I think if you hide the Column headings and/or Title using Display, that when you copy and paste data into another area, the hidden title/headers should not be copied. Currently, that info is copied.
Hiya Codans,
Hi Dana,
We’re actively making some updates to copy/paste so this is great feedback. Out of curiosity, what would you expect the table and columns to be labeled upon copy paste. Also, check out this thread if you’d like to be a beta tester for the new experience: An updated copy/paste experience looking for beta testers
Cheers,
Preeyanka
