When exporting a table with Danish letters, the letters are converted into a weird format.
This is quite critical as I, consequently, cannot use the table data for e.g. duplicate checks etc.
When can I expect this issue to be solved? Thanks in advance!
Thanks for reaching out to let us know about this issue. Since might be a bug based on the information you’ve provided, I would recommend reaching out to the Coda Support team by clicking the ? in the bottom right corner of your Coda screen and submitting a bug report with this information.
Tagging on to Shaina’s note above, would you be able to share a screenshot of the weird formatting you’re seeing? Or, perhaps sharing the doc and spreadsheet in question? Our team gave it a try with a test doc and export, and it seems like everything is showing up correctly.
