Imagine you are creating your own doc with a lot of nifty and handy buttons/control in several sections (imagine buttons like “Add a Task”, “Add a Note”… or “Add Something”)…
Now… imagine you are getting speed in using your Coda Doc with your own workflow… at a certain point you realize:
Wait a sec, but I can be faster if I could use only the keyboard without leving my hands from it (instead of clicking the button here and there)…
did you get the point??? yes… it’s called “shortcuts”…
When we insert a control (button) in the canvas (NB: NOT TABLES, but CANVAS ONLY) would be awesome to associate for each button a custom shortcut (shortcuts should be globals hence a global management among the doc is required) in order to trigger a particular button and, for instance, open a BIG CELL for starting editing…
just some food for toughts for your product managers/backlogs
