Is it possible to connect to Coda.io data from Tilda forms please? Directly or via third party software? Havent found a correct answer yet. Thank you very much, Michal
hi @Michal_Stefan ,
if you talk about https://tilda.cc/ you can connected their forms via Zapier to Coda.
I hope it helps, Cheers, Christiaan
Thanks Christiaan, yes, I meant that one. Really appreciated support! Michal
