We’ve made a small update to the menu items in a Coda doc that affects Pack makers. The three dots menu next to the doc title has an entry for opening the “Pack maker tools”:
Previously this menu item was always visible, even though the large majority of Coda users have no use for it. We’ve made a change so that this menu item is only visible if you have enabled Developer Mode on your account. You can toggle it on at the end of your Account Settings page:
You can also get to the Pack maker tools by using the “Use different version” and “View logs” buttons shown at the bottom of the Pack panel. These will show up for all Packs where you are have “Pack admin” access, regardless of whether Developer Mode is enabled.
Let us know if you have any questions, or ideas for other usability tweaks we should make.
