Hide Grouped Empty Headers
If I group a column, all of the group headings show up even if there’s a filter set to filter out certain items from that column. How can I make it so empty grouped headings don’t show up?
I want to create a table with a lot of information and then whittle it down through different iterations of the table while still using grouped headings for ease of grouping.
Dear @Michelle_Huynh1 ,
This is the article you might want to check out
Just take care that they are not pinned and only the ones with content will remain.
Thanks! I was also mainly wondering if this can be improved because it’s pinning a lot of empty headers (when I create a row but haven’t filled it out yet). Is there a way to not show these automatically? Same with ones that are purposely filtered out. I can understand how it might work for things you’re actively working on, but it feels like it shouldn’t be showing if the filter parameters are purposely filtering them out.
Hi, any update on making this automatic? It’s making it difficult to use as a PPM if all of my completed projects are sticking around.
Update: Nevermind I figured it out. There’s an option in the group by options to disable empty.
Where did you find this option?
