Attaching a screenshot that exemplifies the issue I’m having. I have table with column values “3.11,” “3.12,” “4.0,” and “5.0.” The column is a text column.
When I create a chart from this table, it lists the column values as “3.5,” 4," 4.5," etc. How do I get the horizontal axis on the chart to list the exact values from the table column I’ve selected. It seems to be interpreting them as numbers, and also against some formula that I can’t find where it’s defined.
Thanks in advance for any help!
