I created a table ‘Table 1’ to keep track of proposals my organization submits to funders. One of the columns, let’s call it ‘Brief’ is in Canvas format for which I’d like to have, for each proposal, additional information such as objectives, strategic alignment, partners, project target demographics, etc.
I want this information to be structured and the same for all proposals, so I created a template (Brief Template) in a separate page. The categories mentioned above are the columns of a table ‘Brief Table’ included in the that page .
In ‘Table 1’ I set the ‘Brief Template’ as template for new lines.
The problem is that when I create a new line in ‘Table 1’ and click on the Canvas icon in column ‘Brief’, the canvas expands but instead of having my full template, the ‘Brief Table’ is replaced by this error message “Object not found!”
I followed the solution proposed here (What's the right/easiest way to get a canvas column in a table to be a template?) to no avail.
Does someone know what could be causing this error message?
Thanks for any hint.
