Is it possible to set a formula for a single cell?
Hi,
When adding a formula on a column and using a filter that reflects the row, actually you create an unique outcome for each single cell, but obviously you are looking for something else.
Would you mind to create and share a doc, where you explain what you want?
This will be the best way to get the community being able to forward a proper reply based on your use case.
Kind regards,
//JP
