From managing a single project to planning hundreds of OKRs in Coda, your tasks and timelines can have complex dependencies. For those moments, we’re excited to introduce a new timeline feature that will help you update large and complex projects: enforced dependencies.
Dependencies add a layer of automation and smart logic to project timelines—a way to automatically adjust interconnected tasks so you can focus on the big picture instead of updating every line. Quick note: this feature is available to workspaces on our Team and Enterprise tiers so teams can ensure that their interconnected tasks adjust automatically when schedules change, making it easier to manage large and complex projects.
You can easily set up dependencies through the options menu for any timeline. You can customize how they work for you by defining specific task attributes. Namely, Start date, End date / Duration, Depends on, and Enforcement type. The enforcement types dictate how dependent tasks react when a primary task is moved and can be Flexible, Strict, or Visual.
Once configured, dependencies apply to the base table and all associated views. Any updates to values in the tracked Start date, End date / Duration and Depends on columns will trigger enforcement Flexible or Strict rules. This means your entire project stays in sync and your team stays on the same page.
Dependencies ensure that your team’s workflow remains as dynamic and interconnected as your projects. In this busy end-of-year planning season, we hope this makes managing tasks, timelines, and initiatives seamless and delightful.
