When I tap on the notification when there is a row change, it only goes to the page with the table, but it doesn’t open the changed row.
Also sometimes, notifications also only open some random page in the coda doc, and not even the page with the table the notification was about.
Is there some way to make sure when I tap on a notification, it opens or selects the changed row in the table?
