We are experiencing bad formatting of the conditional formatting pop up window.
Anyone else with the same issue?
Check image below:
Thanks guys!
Check image below:
Thanks guys!
Hi @Higuel_Noroes,
Sorry about that! It looks like I pushed a bug to your document which is one of a handful that are still on an older version. Mind opening up a support ticket (email to support@coda.io and share your doc with support@coda.io as well) so I can get you unblocked? Will get a fix in for the issue as well shortly. My apologies for the inconvenience!
Adam
