Hey there!
It’s an invalid action because your button needs an action formula. Aka you need to wrap your exportTable() inside an OpenWindow() formula.
Hey there!
Thank you @Scott_Collier-Weir so much! Now it works!
Someone else mentioned this issue to me recently and I realized it’s because the dates in the Excel file correspond to the timezone of Coda’s servers, which are in the US. I am planning to work on a solution for this in the next week. In the meantime, if you set your timezone to PDT and choose the “Keep times” option, that should get them to export correctly.
Tried using this pack today and it gives an error about not having the right access. Set up the account, selected the account, doesn’t seem to work.
Hi @Susan_M_Davis! Did you put any restrictions on the access when connecting your account? If so, make sure you restrict it to your entire doc, not just a table (and not a pack). I’d recommend deleting the connected account and setting up a new one. You can do this from the pack settings in the right-hand panel
Thanks. @Courtney_Milligan1 I finally got it working. I’m guessing it wasn’t using the new account I chose so I disconnected and retried it.
Also, found your example and after examining it, saw that you also had to add an openwindow() around the Export function. Got it working. Thank you.
