Hello,
Wondering if anyone else is experiencing an issue I noticed about a day and half ago. Recently we were impacted by the issue of how background tables were set to load differently (about a month ago, which has now been reversed), and I’m wondering if this is a new attempt at efficiency that has caused a similar issue.
Issue: When I now use the document’s Global Search or hovering over a Lookup value, the buttons in the referenced table are grayed out. If you go directly to the table the buttons do not have an error and function correctly as they had been. The table referenced is a hidden table, so the point of the buttons is that they can be used and referenced in these hover views. Up until about a day and half ago, we had the buttons in place for at least 6 months and didn’t have an issue, so I’m guessing there was a change at CODA.
These buttons were extremely helpful for my team in navigating the document while changing filter values, creating tasks, etc.; so I’m hoping it can be turned back on.
It is occurring in all documents.
Looking at table reference from Document’s Global Search:
Hovering over Lookup Value:
