How did I get into Klingon Print Mode?
This was generated by simply selecting the Print | PDF option.
There was a Chrome bug that we have had to work around. Are you on the most current version of Chrome?
Wondering if it’s this same issue…
@BenLee, here’s the details:
Works fine on this version of Chrome (the latest) running on Mojave.
Fails on the same version of Chrome (the latest) running on Catalina.
I’m having the same issue now with the latest version of Chrome running on Catalina
Version 81.0.4044.138 (Official Build) (64-bit)
any help is appreciated!
This looks to be an issue with italics. For now, if you remove those, it should print fine.
We’ll look into it and see if we can find a fix.
Thank you Ben!
I’m sure other people have cases when text needs to be in italics, but will see if we can get away with going italic-free for the time being.
Thanks again!
